1 - 2 of 2 Posts
I've had a bit of a trial with the Brodix heads I put on my 383. I took them off cause they were more trouble than they are worth. I put back on the 2.02 heads and adjusted them for zero lash. I have about a thousand miles on them now and want to adjust them again, only I can't find the adjustment chart. Plus I need to know how much each push rod needs to be able to turn once the adjustment is complete. I am running comp cams metal rollers and a 274 xtreme energy cam. Thanks, Mike.
Tazz
just a suggestion but...
you may get a response if you go to the engine forum and ask this question...this is the introduction forum and not really meant to get a response to a question forum.
Tazz
Rat Rods Rule!
1 - 2 of 2 Posts
