Could anyone tell me if its possible for a Torque Converter to leak back into a ZF 5HP24 transmission and cause a malfunction of the trans?
If the car sits for a couple weeks the trans does not want to shift out of first gear for about two blocks, then it seems fine. I also have a interior noise around the trans hump, sounding like a fluid pump not full. Sort of like a pump sucking air and fluid mixed.
The ZF transmission is sealed so I'm not able to check the fluid level with a dip stick.
Paul
Paul
