I have heard differing opinions on this question and wanted to ask the experts out there. Also, what weight of oil would you suggest?
Zinc additive is not needed for a roller cam; the wear pattern on a roller is much different from that of a flat tappet to where ZDDP brings no benefit.I have heard differing opinions on this question and wanted to ask the experts out there. Also, what weight of oil would you suggest?
bad info.. deisel oils DON't have it and haven't since 2010ZDDP is what its commonly called. zinc is just one part of it. Motorcycle oils still have zddp same goes for rotella and a few of the desiel oils. They are recommended for cam break in.
Normal car oil no longer has zddp in it. Not sure about royal purple and the performace synthetics.
not sure if the shell you get up there is the same as the usa.. but the epa emmission laws on over the road deisels... they pulled most of the zinc out.. as the converter in the 2010 up trucks can't live , and the epa mandated they last x amount of miles...The new Rotella T oil still have Zinc in it. Just not as much.
It's still very good oil. They just adjusted the anti-wear formulation.
There is a lot more to it than just the Zinc.
Its still one of the best oils you can buy.
There are still lots and lots of speciality "racing" oils that still have all the zinc you will ever need.
It is the over the counter-off the shelf- parts store passenger car motor oil that got the reduction in Zinc.
i would agree in principle, but what, exactly, would be needed to be done to a gen 1 SBC to convert it over to roller lifters?ZDDP is an extreme pressure lubricant that is necessary to prevent scuffing when using a flat tappet hydraulic or flat tappet solid lifter camshaft. No such extreme pressure lubricant is needed with roller tappets. Just clean off the preservative oil that the factory puts on them to prevent corrosion, dip them in off-the-shelf engine oil, install 'em and run 'em.
Here's a tutorial showing the procedures to prevent "fraggin" a flat tappet camshaft....
http://www.crankshaftcoalition.com/wiki/Camshaft_install_tips_and_tricks
In today's world, it makes little sense to jump through all the hoops to use flat tappets, when for just a little more dough, you can install rollers and forget about it. There may be better deals around, but Competition Products sells a set of Howards retrofit hydraulic roller lifters and a roller cam for about $600. Add a Howards composite distributor gear for about $100 and you're done. No worries, no headaches and much better performance due to the increased "area under curve" of the roller cam.
Okay, thanks for all of the great information. All I am running is a mild pretty much stock Chevy small block (vortec) with a roller cam...headers with glass packs and that is it. It is a new engine so I want to make sure it is protected well. Sounds like I just need to run some Rotella or similar.
Thanks!
Read the last paragraph of my post. This is for a Gen I that has no provision for the OEM roller. Probably the easiest and least cost approach is to locate a pick-up with a provisioned block, many were used with flat tappet cams in them from 1986 through 1995. For 350 roller tappet blocks look for casting numbers 10243880, 14011148, 14088526, and 14093638. There is a block in this period casting number 14101148 this is a flat tappet truck block, its casting number is very similar to 14011148 which is a roller provisioned block. the 880 is the L31 Vortec block but it actually starts to show up in 95 production with a flat tappet cam and the pre L31 steel timing cover.i would agree in principle, but what, exactly, would be needed to be done to a gen 1 SBC to convert it over to roller lifters?
I haven't been able to pin down the first automotive roller cam. I know the first automotive hemi was the 1912 Peugeot Grand Prix motor.A lot of young hot rodders and enthusiasts think roller cams are a new innovation! Jester
rollerized lifer cams or rollerized cams.. that ran in roller cam bearings?This has nothing to do with the tread : I ran roller cams back in the 1960s, and my father did in the 50s!! With Zddp!!! A lot of young hot rodders and enthusiasts think roller cams are a new innovation! LOL
Jester
That IS funny. Roller cams were factory original on H-D, going at least as far back as the '20s.A lot of young hot rodders and enthusiasts think roller cams are a new innovation! LOL
Jester
