Crank Trigger and Cam Sensor
1.6K views 6 replies 3 participants last post by  Rick WI
Wondering what the computer expects to see when it receives the crank trigger and cam sensor signals, Ford Mod Motor and GM LS. Where's the missing tooth supposed to be? Why does the computer need to see the cam
#4 ·
What engine are we talking about here? Ford use a 36 minus 1 reluctor wheel and the place missing a tooth represent cylinder number 1. One tooth equals 10 degrees of rotation, 360 degrees divided by 36 teeth. Don't forget these are 4 stroke engines and the cam sensor is needed to determine which stroke the cylinder is on, be it intake, compression, combustion or exhaust. The LS1 used a 24x reluctor wheel, then switched to a 58x one later on.
Typically the cam sensor will be telling the ECU when #1 is approaching TDC for injector firing purposes. Crank trigger controls spark. You can make them anything you want but anything except what's correct will mean a non running engine.
