Hey guys Im welding in patch panels on my project &I have about an 1/8 in gap in one spot any ideas how to fill it?
you're much better off to let it cool naturally rather than shrink it with a cold rag.trees said:Old trick that works for me is to use pieces of coat hangers. I shape about 6 inches in the form to follow the lines of the panel and hold onto whats is left over. I place the formed piece in the gap and spot it in place and then form and insert the distance of the gap, spotting as I go. I then go back with wet rag in hand and continue spotting and cooling until the gap is filled. If you think it is getting too hot take a break and trade out the water for fresh, cool stuff.
I agree with that. If you are concerned about distortion, then slowly preheat the panel before welding, and after welding let it cool naturally.Lizer said:you're much better off to let it cool naturally rather than shrink it with a cold rag.
exactly. A wet rag will just force it to shrink too quickly and distort. I always just skip around and feel it by hand. I do sometimes blow on it but it's after it has almost cooled all the way down naturally. The tell all sign is how it looks when you grind on it. If you test the waters even slightly you'll have a hard time to making the weld disappear cause it will be slightly distorted really close to the weld. If you take your time you have no big warpage you can feel with your hand nor will you have that slight warpage that makes it hard for the edges of your weld to disappear when grinding. That's the key to making it disappear and having confidence that it's penetrated well. Obviously that includes a well penetrated weld.Lizer said:you're much better off to let it cool naturally rather than shrink it with a cold rag.
