Status
Not open for further replies.
177 blower on 396 BBC - questions
1 reading
8.7K views 9 replies 6 participants last post by  AutoGear
I am thinking about putting a blower on my 396 (402), which sits in an 18' v-drive boat, and am looking for some guidance as far as how many modifications I would need to make to my current setup work, or if it is even practical. Current motor specs are :
cam 396 375 HP cam, (242 / 242 , .520/.520, 114 LSA)
closed chamber, oval heads ("702s")
L2240 NF forged pistions, with this combination my measured Static CR is 10.3
stock cast crank
holley 650 DP performer 2 intake
It runs perfect, tops out about 5500 RPM with current gears / prop.
I am leaning towards like a weiand 177, for the smaller profile. I think I can get the CR down to about 8.5 by swapping back to my 049's, which I replaced to get the CR up in the first place, maybe closer to 8 if I use a thicker head gasket (currently .022 steel shim LS6 gasket). I can get 93 octane here.
I don't plan to run a lot of boost, and am not terribly concerned about increasing the top end significantly..really excited about torque. I am lucky to get 10 trips in to the lake in the summer, so it doesn't see a lot of "lake miles". Aside from the obvious things that need to change (heads, carb, distributor (currently HEI)), what other things do I need to concern with ? Some specific questions that come to mind:
- How hard is it to get the timing right? Will this require special consideration with a mild setup such as this ? Do I need to get fancy and use for example an MSD boost timing master ?
- I would like to stick to a mechanical fuel pump - what would you guys recommend here ? I assume stock is a no go.
- would the cast crank/rods be ok in this situation ? If so does it need to be double keyed ? I know steel is preferred.
I've not started this yet, and am in no hurry so I'm open to suggestions. Any input would be greatly appreciated.
Thanks !
#2 ·
This is at least the third post I've read this morning where the OP has mentioned thicker head gaskets to lower the static compression ratio. I cannot begin to tell you what a bad idea this is. Higher static compression ratio with a tight squish is doable many times, whereas a slightly lower static compression ratio with no squish might detonate. This thinking comes from John Erb, chief engineer at KB Pistons. Head gasket thickness should be used to set the squish, not the static compression ratio. Piston crown design and combustion chamber volume are used to change the static compression ratio. You do this when you are planning your build, not as an afterthought. :spank:
As far as fuel pump, let's say you are making 600 hp. Fuel is used at the rate of ~1/2 lb of fuel per each horsepower hour at full rpm's, so let's assume 300 lbs of fuel will be used each hour of operation at flat out. Since fuel weighs about 6 lbs per gallon, we can divide 300 by 6 and find that the motor will need 50 gallons per hour at wide open throttle.
The other thing is fuel pressure. You're still using carburetors and carburetors need a maximum of 5 psi to keep the bowl(s) full during operation. More pressure than that can override the needle and seat in the bowl and allow the fuel pump to blow raw fuel into the intake manifold, creating a tuning nightmare for you............................. NO CARBURETOR ON THE PLANET NEEDS MORE THAN 5 PSI.
#3 ·
Thanks guys, I do in fact have a complete 454, carb to pan, in storage that I could use that I picked up a few years ago. I don't know what's in it, but it would make a great core for a build like this. I thought it might be easier drop one on my 396, but it is probably a better move to just build it up from scratch, and have the extra cubic inches.
Thanks for reminding me of quench.. I remember now that I had to search extra hard for the steel shim .022" gasket I'm currently using now to achieve .040" quench.
Are piston rings a big consideration when using a blower ?
Thanks!
#4 ·
Its really not alot of work just dropping the SC on there, Why not just do it with what you have and give it a run, you might be surprised.
I am running a 454 with a 250 SC and a single 750 DP, Runs great, I have brand new blower 750's in the box but not in ANY rush to mount them.
Thanks for the input on this guys.. a few more questions on timing-
- In regards to getting the proper timing curve, from the research I've done, it seems like most people do not run vacuum advance on blower motors.. why is that? I know it is best for cruising/economy purposes (which if you have a blower, you probably don't care much about those), but it seems that you need 20+ initial advance for the thing not to blow up at idle, so people seem to lock out timing, or set initial to 20+ and run a boost retard box. Would an alternative be to keep the initial timing less to help with starting, then rely on the vacuum advance to provide the ample initial timing ? Although, does vacuum advance kick in even when turning the starter over (in which case that wouldn't help with hard start issues). Honestly for my application, cruising speed is probably 2500+ rpm so I could probably get away with locking out timing, if I can get the thing to start properly.
To me, it seems there is very little difference between running locked out timing and using a boost retard... the difference being that you will have a little bit less timing at initial and lower RPM's (what is the benefit here ? Easier starts, and you get to run whatever initial timing you want?)
Also can anyone recommend a good aftermarket distributor that is easy to adjust the mechanical advance curve ? Do most of them (MSD/Mallory,etc) have vacuum advance or are they strictly mechanical?
Thanks
#6 ·
I run 18 deg initial, no vac, and 34 total, all in at 3000, with a BTM, street driven 8-71 383. I never have kick-back issues and the motor is far from hard starting, it fires on the first hit of the ignition, seems like not even one full roll. You shouldn't have any problem with no vac, like FBird said.
#8 ·
Thanks guys, don't worry, I'm not buying anything for quite some time - just getting educated at this point... Once I start, I'll keep it simple and buy the proper components as I start tuning.
I didn't realize there is no vacuum when the engine was under load - I thought it was more RPM determinate..so that is definately helpful..
Thanks!
#9 ·
Whatever you do pease do not put a blower on the engine as it sits. you said you are at 10:1 or so now. This is not a good starting point. If you do you will be putting that 454 in sooner than you planned
Save
#10 ·
Make sure you have a good, consistent source of quality gasoline. I had plenty of guys get towed into the marina with hot boats, hot tempers and hot girls; a lot of times because they got mystery gas at Cooters Bait and Tackle. Full of dirt, water, wrong octane, etc. Make SURE you know what you're putting in the tank. Having to dump say 60 gallons, flush the system, refill with proper gasoline; oh and pay for the tow...makes the bikini girls, and your wallet VERY unhappy LOL
Status
You have insufficient privileges to reply here.
