I guess this would come under the heading "Hot Rod"?
A young and up-coming hot rodder here (really smart kid actually
) built a go-cart with an 18 HP Briggs Intek engine and while going through this engine he had me mill .025 off the head to increase compression. Well it worked out OK as far as raising the compression but now the starter will not crank the engine most of the time, it depends on where the crank/piston is positioned when the starter is engaged. I do not know the exact compression ratio but a compression gauge reads 175 PSI so it must be right up there! Now my question is, would it be OK to reassemble this engine using two head gaskets to drop the compression back down? I realize this would probably end up with a ratio slightly below specs but at this point he decided the performance gain was not worth the trouble and has decided to put this engine back on his dad's mower and use a Kawasaki engine on the cart. What do you think will, the double gasket work? Would it drop the compression too much?
BTW this kid is 14 years old and built that cart from scratch including rebuilding the engine. It looks really good and IMO this fellow has a real future ahead of him!
