I'm helping a friend convert his 351W from points to HEI distributor. Believe the motor is from a 70's Torino. The distributor fits just fine in the intake, but the oil drive shaft (with the hex head) on the new distributor is smaller than the existing oil pump shaft that sits in the block. I've called everywhere and looked everywhere I can think of on line to find an answer with no luck. Does anyone know if they make a replacement shaft to fit an existing oil pump shaft? (I need the drive gear and the short shaft that it attaches to that slips onto to the distributor shaft) Also, that shaft just slides on and off with a key in the center of the shaft to hold on to while rotating. Should this piece be drilled and pinned? I was figuring it would be held in place when the distributor is set on top of it and bolted down.
Thanks!
Chris
Thanks!
Chris
