Hello i have a 1940 or 41 chevy coupe ,dont know which one cant read the vin tag,but i would like to do a complete frame swap does any one know what frame would work under this car so that i can get the ps ,ds upgrade and the rearend.
The tires would only point straight ahead or rip the fenders off. A little tough to go around corners. I have attached a photo of the front wheel at full compression of the front suspension. The Camaro front end is too wide. I could have bought narrow a-frames and special offset wheels. But with all of that expense plus the expense of rebuilding the front end, it was much cheaper to go with a replacement frame and the MII. Plus, the steering box interfered with the radiator.NEW INTERIORS said:They will work fine... if you wanted it to sit low, all you had to do, is zee the front,, Then you can set it down as low as you want...You set the ride height when installing the clip...![]()
I stand corrected... I guess I been up too long today... :drunk: :drunk: I have never used one in that car,, I thought I read where someone used one,,Guess I read wrong...We did use a S-10 clip in a 40 dodge once..It fit very nice,Like it was made for the car,,Just had to move it back a little because the steering box hit the grill a little..Couldn't even tell it was back a little..Sorry Redsdad.. :drunk:redsdad said:The tires would only point straight ahead or rip the fenders off. A little tough to go around corners. I have attached a photo of the front wheel at full compression of the front suspension. The Camaro front end is too wide. I could have bought narrow a-frames and special offset wheels. But with all of that expense plus the expense of rebuilding the front end, it was much cheaper to go with a replacement frame and the MII. Plus, the steering box interfered with the radiator.
40-41chevycoupe said:Hello i have a 1940 or 41 chevy coupe ,dont know which one cant read the vin tag,but i would like to do a complete frame swap does any one know what frame would work under this car so that i can get the ps ,ds upgrade and the rearend.![]()
I think building a new frame would be a much better alternative than trying to cobble up a frame swap. I actually considered doing this. You can have it follow the stock frame configuration back to the rear fenders so the firewall and floor can be stock. You can use the stock body mounts. Then, at the rear fenders, you can move the rails in and tub it for some really wide tires. You could also notch it to make it real low in the back. And the stock body mounts could be moved inboard at the same time. You might lose the one directly over the axle depending on the notching and lowering. But these cars used 22 bolts to hold the body to the frame, so you could probably afford to lose 2!NEW INTERIORS said:It would be much easies to build a frame for it,, And you can set it up like you want...Finding a frame to fit, can be a lot more work then building one sometimes..![]()
If you do this, remove the lower control arm and run a rod through the bolt holes so that as you push the bar through, it will tell you where to put the pivot point of the rear control arm that you will add. The centerline through the control arm holes needs to cut exactly through the center of the rear pivot. I've seen this botched more than once.redsdad said:I do intend to put braces (at least on the rear) so the lower control arm bolt is in double shear.
