Ok guys been away from the drag racing scene for a while and haven't ever posted on here much. Putting a little bracket motor together it will either be going in a Malibu or a Vega in either case it'll be in a 2700ish pound car 5.13 gears with big tires (this is for 1/8th) mile. Like I said been outta the game a while see if you guys see an glaring holes or omissions from my build. Engine is assembled but not in car. Not too late to change anything or check anything.
Stock 400 2 bolt (i know I know they make aftermarket blocks now but ive used these 400 blocks and beat on them for years with little or no issue)
421 balanced rotating assembly 4340 eagle crank 3.875
Eagle 6 inch H beam rods
Mahle .030 (4.155) -5cc flat tops
World Products Motown 220cc intake runner 50cc chamber heads. (Straight out of thr box no porting no nothing)
Comp cams 4/7 firing order swap cam solid roller .630/.630 lift 264I 264E @.050 106LSA ( im not one of these guys that think these firing order swap cams give you more power I dont think they do squat in the department on a motor like this maybe they would on something higher end, but ive used them in the past for some reason the valve train seems quieter and could be my imagination but the lash seems to stay set longer)
Matching comp solid roller lifters
Comp roller rocker arms (1.5's)
Stud girdles
Wilson single plain intake port matched to fel pro 1206 gasket (by them)
Intake drilled and tapped to accept Rons flying toilet injection with appropriate pump.
MSD dizzy with crank trigger.
Pistons are -5 cc flat tops that are .010 "in the hole" with .027 compressed head gasket thickness for .037 quench
That combined with 3.875 stroke and 50 cc chambers should get me to around 14.5:1 if my math is correct. This engine will be bracket racing only and run on methanol.
Looking forward to you guys input. Cheers!
Stud girdles
