It does... thank you. I had figured that all out the long way by disassembling the switch and just plotting continuity between posts, but the problem I was having was that all my logic wasn't playing out in the actual operation of the switch.
BUT.. I figured it out. The switch has the mechanical body and then the "printed" board on the back. I found a crack in the back which allowed the contact board to bend out of the way when I slid the switch to the desired position. I was getting intermittent continuity.
The good news is that I figured it out. The bad news is... I've exhausted about 15 possible sources for replacements and the best I can come up with is an aftermarket turn signal assembly that mounts to the outside of the column. grr. I had a perfect 51 switch and then found out it won't work. I could maybe epoxy the board, but I'm on the shop's dime and I don't think the boss would be happy with trial and error.
Thanks to all... Problem solved... or at least figured out.
