I just purchased a Weiand 6 71 blower set up with dual 600 Holley supercharger carbs. I've talk to many people about adding the blower to my existing set up below including a reputable local engine shop. The input that I received was that I could add the blower to my existing set up and not have any issues. Obviously have to get timing, fuel and other items correct but not needing to lower compression or change cam or pistons or heads.
Goal for this motor is 100% street car. If it runs good it might see 1 day at the track just to see what it could do. Otherwise it's basically going to putt around the neighborhood and the occasional pass on an empty street.
I've purchased a mallory dist that I'll lock out and use my MSD 6AL-2 programmable to pull out timing. The pulleys I have will be 10.5% under-driven. I have a BG 220hr pump with regulator and have the necessary size fuel line. Will need to buy AF gauge and boost/vac gauge.
just curious what everyone thinks?
Thanks in advance.
GM 4 bolt main
Probe SRS forged pistons
Probe cast crank
Probe forged rods
Clevite perfect circle (P-Bearings)
Roller Rockers are Scorpion Performance 1.5
Isky Hydraulic Roller Camshaft (Duration 282 / Cam Lift 353 / Valve Lift 530......duration at .050 is 234) LSA 100
Aluminum Patriot Performance 185cc Intake and 64 cc
Manley Pushrods
Cloyes Gear Drive Set
Compression 9.86:1 - 9.90:1
B & M 2400 Holeshot torque converter
4.10 posi rear end, Headers
Holley 750 Double Pumper
Victor Jr Manifold
March Mid Mount Pulley System
Electric Fan
Thanks in advance.
GM 4 bolt main
Probe cast crank
Probe forged rods
Manley Pushrods
Victor Jr Manifold
Electric Fan
