6 volt to 12 volt conversion
2.1K views 6 replies 5 participants last post by  cadmanof50s
Can anyone tell me where to start? I searched the forums but did not turn up anything useful. Thanks in advance! :D :D
#2 ·
I have never done this but IMO......
How is the wiring?.... If it's old and worn.... replace
Alt.... I'd go with a newer style, internal regulator type (which will take care of your old 6v regulator)
Battery
Light bulbs, you’ll have to change every one, to include the gauges, dome, marker, head lights etc…
Fuses should be OK, but if I’m going thru all this trouble I’d replace them along with the wiring
Starter
Radio
AC/Heater blower motor, if equipped
Horn, should work for a while at least
Gauges, if they are electrical they will have to be rebuilt or a voltage limiting resister installed
Probably missed some things
#3 · (Edited)
new drive train ?
6 starters will work ok. just dont crank more than 5 seconds on them. you should have the engine tuned so it will start quicker than that, back in the day we used to put in a 6 volt starter in a 12 volt car so we could get the car to start in below ZERO weather.... have you checked the links at the bottom of this page ?
May I ask, what is it that you don't like about the 6 volt system?
Do you have a starting problem? or are the headlights too weak? There are a number of things that can be done to improve these without having to convert.
I was going to convert my old '48 to 12 volts during the restoration ..and I am so glad I didn't now.
I wanted to switch to 12 volt because 6 volts components were hard to get..BUT there is NOTHING I have not been able to get between the local jobbers, specialty suppliers and of course..eBay.
No matter which way you look at it, converting the system is a PITA. It takes money, time and effort. And yes, there are benefits..I won't deny that, but there are ways of improving the drive-ability of 6 volts cars/trucks.
Vic
