1981 malibu. leaning more towards the 7.4L because of aftermarket and tech availability. Not much info about the 8.1L. have a th400 that is good for say 900 horse. any suggestions? track only.
Id go with the 7.4L. You can always bore it out and stroke it if you really need more displacement. I dont see the need tho, a 454 should be capable of anything you want it to make, unless you happen to be building a 6,000HP top fuel dragster. Then you might want more cubes, but probably more than 8.1L. Since I doubt that's what you're after, the 454 would be just fine.
If you want the 496 I think you might be better off building a 496 out of a 454 rather than buying the Vortec 8.1L. I believe there were quite a few components that were redesigned in one way or another and could make parts interchangeability difficult.
CAUTION>> The only conventional BBC engine parts that fit/interchange with an OEM 8.1 are the bearings, oil pump, oil pan. EVERYTHING and I do mean everything, else is different. The 8.1 is a BBC in name only...
Related Threads
Hot Rod Forum
posts
2.2M
members
183K
Since
2001
