85 Chevy 1/2-ton 12 bolt rear diff problems
I have a GM truck 12 bolt in my 85 Chevy 1/2-ton shortbed weekend hot-rod.
http://www.cardomain.com/ride/3001366
It's no huge powerhouse with having around 350 horse and runs high 14s with 3.40 gears. The TH350 has what I think is a stage 2 shift kit in it as it shifts very very firm at WOT. Originally it had a 2.76 open 12 bolt that I swapped in a 3.40 Gov-lok (non-working) last summer, a couple months after I had the new cam and heads put in. It ran just fine for a year, including some drag strip outings where I probably put about 20 runs in, plus around-town driving. I haven't had one problem at all with this diff. No noise, nothing.
Here's a quick rundown of the problems I'm having:
- July 2009 I see a local specialty rear-end shop is selling a rebuilt Eaton posi. I buy it to replace the non-working gov-lok
- took it to said shop for install. They had to TORCH out the gov-lok because it was all seized up in there. Put new diff in, all new bearings and seals, axles were said to be fine, R&P was said to be fine, put it all back together
- 5 days later the R&P wipes out after a WOT run through the gears, without any indication or previous noise. Wiped out meaning lots of gear noise and howl
- take it back to shop, they put in Yukon 3.73 thick gears to fit my carrier. I pay parts, they pay labor
- at end of break-in period, I try a WOT run. I get some gear noise. 4 more WOT runs (not at track, just around town) doing 1-2 shifts = wiped out R&P
- take back to shop, they replace gears very reluctantly and after a BBB complaint with new Yukon 3.73 thick gears again. No cost to me. They do not give me any explanation as to why gears failed. They do initial run-in of gears
- after break-in period is done, do an oil change, and first WOT 1-2 shift I do, I get some noise. Not a ton, but some. I live with it for 250 additional miles. I do another WOT 1-2 shift this past Friday. A little more noise but hard to tell. I do another WOT 1-2-3 shift yesterday and I got more noise. At this point I feel doing 2 or 3 more WOT runs will again ruin the R&P.
So, this is where I am. Something I feel is causing the pinion to move under the torque spike during the 1-2 shift and possibly 2-3 shift, mashing it into the ring gear. My thoughts are either:
a) crush sleeve is moving. Why?
b) torching out my gov-lok caused something to tweak. Like what?
If anybody can please help me with this, I would sure appreciate it. I'm going to call the shop back now and report my results. Thanks!!
