it'll go dead lean and try and die when I come to a stop at a light (anywhere between 16:1 and 18:1).
this is a fuel supply issue.. or a vapor lock issue..
do you have a fuel pressure gauge to monitor the fuel pressure?? where you can see it ... even if its just a temporary installation..
does the electric pump have to pull fuel up and out the top of the tank. if so.. is there any way to install a low pressure booster pump in the tank to supply your conventional pump.. like an airtex #E3903 that puts out 5 PSI at 35GPM.. probably not enough for a performance engine..
since i am just looking at one issue of the lean out and stall..
if there is no room for that. or a fuel pressure gauge... how about using some kind of digital volt meter with a that will read 15 or 20 amps DC.. breaking into the fuel pump circuit for testing and wiring it right thru the amp meter ports .. to allow you to do some test drives.. if your fuel pump is freewheeling instead of pumping the amp draw will change..
the Fram HPG 1 is a 10 micron element as far as i recall.. again i don't know what you have..
i worry also that you are sucking air when slowing down perhaps uncovering the pickup in the tank..
on a side note.. being a former street racer in los angeles. i heard about early experiments with nitrous.. ball valves to control it.. because of the nature of street racing.. miles were driven.. the fuel tank was a trunk mounted moon. he did not have time to top it off before the race spot..
during the race the almost empty tank left the fuel pump without fuel. just the conventional fuel from the carb.. flames came out the headers. then the fenderwells. and the car rolled to a stop.. the first few inches of primary tube were gone.. and there was aluminum hanging out the exhaust ports. i was not there.. this was relayed to me by another racer. to be sure about fuel pickup locations..
at former job a class A motorhome came in.. 440-3 would overheat and loose power only on uphills.. passed the 10 second cranking fuel fiow test. boss was a former chrysler master tech and WWII PBY flight crewchief. very little escaped him. but we changed a whole lot of things and it still did it.. when the fuel pressure test came up .. flow had checked out at 10 seconds. going up the grade the fuel pressure dropped and the temps shot up..
checking the 30 feet of fuel line.. found the camping world tech who had installed a new generator set had used a multi vacuum tee that said right on it.. NOT For Gasoline.. without cutting the barbs off.. so the pump on long grades was not able to pull enough fuel after the almost 30 feet of 3/8 fuel line was emptied . the engine leaned out.. when we performed the fuel flow test again with that tee in place.. after 10 seconds the fuel flow reduced.
back on the carb.. i would like to know if that model has the hidden under the air cleaner stud air bypass screw... if so.. open that up.. and close your throttle settings farther.. to expose slightly less of your idle transition slots..
during idle.. there should be really not much fuel coming from the idle transition slots as there is more of that slot uncovered above the throttle blades.. all your IDLE fuel control should be on the idle mixture screws.. changing idle air bleeds does very little for that.. unless you have made major size changes.. changing the idle feed restrictions does effect the way the idle mixture screws work.. if the IFR is too small you will back out the idle screws and still be too lean... if the IFR is too large.. you will need to keep the idle mixture screws farther in than you would expect..
off idle.. below 1200 rpm.. you may want to use a mirror and a timing light hooked over the coil wire or one of the spark plug wires while a friend watches your tachometer.. the timing light aiming down the carb primary throat to light up the primary MAIN fuel flow from the booster.. see what RPMS the primary booster starts to flow at.. so work below this RPM to begin to the idle transition circuits
see if your wide band air fuel display says about idle .. idle transition below the primary operation.. i should tell you that the idle transition circuits operate part way into the primary main operation.. so you have both going say below 2400 rpm.. it varies on carb size and engine displacement..
idle feed restrictions limit max fuel flow thru the idle and idle transition circuits.. idle air jets adjust the fuel curve.. how much fuel gets pulled up and over thru the IFR at how much vacuum is exposed to the idle transition slot. so looking at tuning the idle transition circuits with the mains flowing.. does not good..
if you spend a little time on the idle transition circuits.. you may greatly improve the out of the hole effect your car has. it may also effect your fuel economy.. as around town cruising RPMs and lower highway speeds.. you are mostly working on the idle transition circuit and the lower end of the primary main circuit. above 2500 or 2600 the throttle blades are past the idle transition slot.. so there is no pressure change across it and it stops flowing for the most part. at that point you are running on the mains..
sizes of idle feed restrictions, idle air bleeds, primary jets, primary air bleeds, emulsion jets.. all effect different parts of the fuel curve and every motors needs are slightly different. unless you are building identical motors on an assembly line.. that is why there are wide band air fuel displays.. to assist in tuning the different components in the carb to meet you exact fuel curves.. that is why i don't get into sizes.. its a diagnose with testing..
i do seat of the pants testing when i do something like adjust the APT settings in a quadrajet.. a quarter turn of a time upward from a minimal setting that just barely lifts the primary metering rod hanger. and the owner behind the wheel doing 15 foot long part throttle acceleration tests..
it will spit at the beginning.. but when i get close.. you should see the changes.. not just in how the car will burn rubber just off idle.. but the size of the smile on the owners face.. this takes only a few minutes on some.
i hope i have splained this well..
sorry for the wall of info .. related and partially related..
wayne...
