So I just got done replacing my water pump on my 69 el co and was looking under the hood for leaks when I realized I forgot to hook up the wire to the back of my alternator. When I touched it it hit part of the block and sparked a bit. I ran around the front, shut off the car and disconnected the battery. Hooked up the 1 wire to the alt and went to reconnect the battery. Positive on, then when I touched the negative cable to the post it sparked a good bit.
Thought it strange but put it on and noticed the wire from the alternator got real hot and started to smoke a bit.
What happened? Did all the juice the alternator stored up not being connected initially just try and go to the battery once I connected it?
