My 2004R is from a 1988 RWD Cutlass Supreme. I didn't install or wire the transmission so I don't know what all the connections are for. The lockup feature works in 4th gear only, and disengages when the brakes are applied or moderate to heavy throttle is applied.
But I do know that currently power to the TCC lockup feature is provided from the brake switch through a vacuum switch (on ported vacuum) and then down to a 2 prong plug on the passengers side of the transmission. The 2nd prong of this plug has a wire running from it over to a 4 socket plug on the drivers side of the transmission. The other three sockets have no wires to them. This is all the external wires on the transmission (other than a neutral safety switch).
The 2 prong plug on the passengers side does not have continuity between prongs when the car is shutdown. I have not checked it with the car running.
How does this simple circuit control the lockup feature?
What I want to do is add a rpm switch that will only pass current through if a signal rom the tach exceeds a certain rpm, i.e., add another "check point" that is speed related before lockup occurs.
John
John
