I purchased Rustbeeter about 2 years ago. It does work as promised, removing corrosion from places no blaster can reach, and without removing ANY metal, not even on a molecular level. It is a superior product for removing rust and corrosion, especially from small or intricate parts. I had a severely rusted gear on a threaded shaft, rusted into one piece. After 3 weeks of immersion the rust was gone, and the gear was free to turn on the threads again.
If you need a part cleaned quickly, this is not the product for the job. If you want near perfect corrosion removal, I know of no other product that does it better. Note this product is a chemical "chelation process", and does not dissolve the rust, but turns it back into steel or iron, and instead of leaving small pits on the good metal surface, it actually causes the oxidized metal to return to iron or steel, resulting in a surface that is closer to the original unrusted surface. (and if the rust was fairly light, it's ready for paint!)
There are major limitations however. As a food by-product it has a serious problem with mold, and within weeks there is an ever-present layer of mold on top of the rustbeeter. Persons having mold allergies shouldn't use it. And after 2 years of use, the product is starting to reek from the fermentation process and at this point can only be used outside, a problem during winter as it will freeze. It also attracts any bug that's attracted to sweet foods.
Another problem (or advantage) is the ability to remove almost any type of paint. I stuck a lightly rusted license plate into the rustbeeter, and 2 weeks later not only was all the rust gone, but so was all the paint. We now use it to strip paint off small and intricate objects like antique house door locks, old metal toys, antique tools, and much more. It's great for removing overspray from chrome or plastic pieces!
This paint removal situation does create another problem, as it can no longer be disposed by the suggested method of sewer or septic. With paint solids now in the rustbeeter, it is classified by the EPA as a HAZ-MAT!
One more thing - This product is not for use with some non-ferrous metals, and will destroy aluminum quickly. It will remove corrosion from brass, copper or bronze, but check it daily.
Want more info or assistance with this product, e-mail me. (And note I have no connection with the company, nor do I sell it.)
