Anyone had any problems with holley street avenger series
2 reading
4.1K views 13 replies 7 participants last post by  k-star
I bought a new holley street avenger 670cfm. And put it on and the car would not go above 2,000 rpm without cutting out and back firing. But below 2,000 it ran great and idled prefectly. Just curious if anyone else has had this problem are might give me some ideas on what to look at.
#4 ·
Was it backfiring through the carburetor or the exhaust (after fire). Normally if you have a backfire through the carburetor, it is an indication of being too lean. An afterfire (backfire out of the exhaust) is normally an indication of being too rich. This can be caused from the carburetor being out of tune, or the ignition system not being set up properly.
Well i was running a 750DP and it ran fine i swapped to the avenger and all hell broke loose. It was backfiring out the exhaust. As for where everything is set it was put on straight out of the box no tuning. I thought carbs were supposed to remotely close to running ok out of the box.
#6 ·
carb
Well sometimes you can just bolt them on ,but most of the time they will need some tuning. I just put a avenger on a customers car and it started right up and idled close.... But the front float was about 1/2 turn to high, and the idle screws needed some adjusting.....
You really need to check the float levels.....
Are you running a vacuum advance on the distributor.....
Keith
#8 ·
carb
Any chance you have the hose hooked to the ported vacuum on this carb and it might have been on the manifold vacuum on the other carb...
just for the fun of it put your timing light on it and tell us what initial and total timing you have...
Keith
#12 ·
The Avengers are no different than any other Holley carb. There is no magic making them somehow bolt on and go as they would like you to believe.
Avenger =
Powevalve blowout protection-A drill bit and check valve kit worth $1.00, maybe.
Secondary metering block
Quick change secondary spring kit-$20
Shiny finish
#13 ·
Well i had put the carb on a couple of months ago on my old motor and thats when it ran ruff. Now i have a new motor and just got it started today and it was running the same as it did before. So tommorow im going to check the float level and see how everything sits. Im going to try and do some tuning and see what happens.
