Auto painting set-up that I can also use w/ house paint
1.5K views 7 replies 7 participants last post by  novafreek6872
I need to paint my house (inside) and was planning on using an airless sprayer. Then, I started thinking that if I'm gonna spend $200 maybe I can spend a little more and get something that I can use to paint my car. Probably never happen, but i'd be nice to have the option.
Anyone know of a reasonably priced set-up(preferably HVLP) that can handle both?
This way it comes out of the "home maintenance" budget and not the "project car" budget :D
#3 ·
Probably not in HVLP. I used an old style, remote 1 gal paint pot type gun to paint the inside of my pole barn white. I used a large nozzle (DeVilbiss gun) and thinned the gallon interior gloss about 15%. This worked very well with the pot pressure turned up a bit. I could hit the peak of the inside roof and get good coverage.
#4 ·
I dunno.. try using the excuse so you can get your car paint gun, then just paint the house by hand. I dunno if anything works better than the standard Wagner Power painter, but I got one and I stained my deck with it, then I later painted a wooden fence, and I have to say.. it did a good job of painting my face and arms. They don't seem to have a reputation of being very worthwhile beyond the first job you use them for.
#6 ·
You Can Do It!
Unless your house is brand new, your best bet is to get yourself an 18 in. roller w/shorter nap depending on how deep/thick the texture of the surface. Brush and roll w/o getting too far ahead of yourself so everything blends nicely and you can get a house done supprisingly quick when you compare it to everything that you would have to mask off for spraying. Airless is the only way to go for walls. Air- Assisted- Airless, HVLP, and conventional air(automotive type ) sprayers are all good for trim. The conventional is what you want for your car. Good Luck
