B&M Mega shifter issues
9K views 6 replies 6 participants last post by  ericnova72
Just installed mega shifter and cannot get it to shifter into low on my th350? Tried all adjustment such as cable and lever ? If I removed threaded swivel part shifter on cab with make all shifts but hooked up only park thru drive? Instructions says th400 should remove bolt and nut inorder to shift properly should I remove and try?
#4 ·
Did it come with a new lever? If not you'll need to buy a B&M lever even if the instructions say you can use the stock one. I had the exact same problem with a quick silver. My trans guy told me there are at least a dozen different levers for all the different shifter manufactures and he's had to fix a lot of trannies because of the trans being in between gears
