Best way to pull an engine from a full size GM van?
21K views 14 replies 12 participants last post by  Arrowhead
Wow...what a tight looking spot. I'm assuming the engine has to come out the front instead of through the door? any tricks to make this easier? The van is the '70-96 bodystyle.
#8 ·
ive done it out the front its a tight one take off the hood grill rad a/c condenser all the acc. including the carb and dist I also took off the motor mounts, cups and towers get one of those mounts that mounts to the intake where the carb goes and make the chain as short as possible if you can loosen up the crossmember
good luck
sr66
#13 ·
obviusly you want to put one back in right?/
cause the easiest way is through the roof ( :evil: man i miss workin in the bone yard :evil: ) yes i will admit ive killed more cars and trucks than ive fixed :D there is a deep satifaction in crushing a yugo ... k cars go really flat ah hh hh sorry i digress
sr66
