Good Day Gents
1976 Nova, Big Block installed and could not get the valve cover over the power booster. So, I had to go to manual brakes. After much questioning and research, I found (hope and pray) that I can just buy a particular master cylinder and install it WITHOUT changing anything else. So I found one that fits in the stock location of where my BOOSTER mounted to the firewall, and it fits nicely, no plate or adapter...
Problem is I need instruction on how to attach the adjustable pushrod I bought to the master cylinder and the brake pedal. Mine is at an angle. Most pics online I see are straight (from the notch on the brake pedal 90 degree straight perpendicular to the firewall). Does it just sit inside of the master cylinder hole that... Well, here are some pics:
