There is no default number that would mean anything because rebuilders most often use an inexpensive cast piston which has a shorter compression height than the stock piston did. Compression height = the distance from the centerline of the wrist pin to the crown of the piston. Plus, you have no idea how much the rebuilder cut from the block decks to square them or if he did any cutting at all.
It looks to me like you are trying to "wish" your way into this build and it just ain't gonna happen until you get up off your duff and do some measuring. By the way, stand the rule on its EDGE across the edge of the bore to check piston deck height. I forgot to mention to use the edge of the rule, not lay it flat.
Your dynamic compression ratio figures prove what I said earlier. The motor is gonna be a pig. Too much cam. I think you're more worried about rump-rump to wow the zombies down at the drive-in than you are about screwing together a good combination. Again, just my opinion. Now, don't get me wrong, there's nothing wrong with a rump-rump cam, but you must build the motor with sufficient static compression ratio to support the cam if the motor is expected to pull the hat off your head. You don't have anywhere near enough s.c.r. to support that cam. If you bolt together what you have outlined and take it to the drive-in, for God's sake lie to the old guys there and tell them the motor has 10.5:1 compression ratio. That way, they won't laugh at you.
A pump gas motor should have around 8:1 dynamic c.r. With good gas, the proper cam, a good tight squish and everything in the combustion chamber de-burred and polished, you could probably get away with 8.5:1 dynamic c.r. Keep playing with the d.c.r. calculator, dropping the intake valve closing point 2 degrees at a time until you get into the 8:1 or better area. Then look up the phone number of your favorite cam grinder and call them up. Give them all your information about the motor and tell them you want a rump-rump cam.
It doesn't cost anything to talk to the cam grinder tech guy and you'll have the benefit of the entire library of knowledge that these guys have collected over the years.
