So the OP is trying to build a 380HP 283... good luck with that... and then planning on hooking it up to an automatic... and plans on turning 8000RPM...
So, do any of the "experts" see any issues with this plan?
Even if he can get that HP, the trans is going to suck probably an extra 10% (?) so you're losing more of your hard-won ($$) HP than a manual trans.
Torque will be low on the 283 also, so AT will be lame.
Then, what's the max RPM of stock TH trans? I'm sure you'd have to upgrade some things at least.
So can you even get up to your Max HP?
If he had said "I want to make this just like a period SBC racer, with period factory parts, etc.", I'd say great, then put a 4-speed in it and have fun with your period-correct nostalgia racer.
However, this just sounds like a "I got these engines that nobody else wants, for free, so I'm going to spend a ton of money trying to build an engine that will put out mediocre power at best, and won't come close to meeting my mostly unfounded expectations, and is a lousy match for the trans, but it'll be the fastest 283 in the county(!), because nobody else in the county has a 283 for some reason... did I mention that I got them for FREE?!" situation.
Why would someone spend the same amount of money on a 283 that you would spend on a nice 425HP/450TQ (ish) 383?
If your goal isn't to "build a car just like Balls-Out Bob ran at the local strip back in the day", don't do it.
I've collected up all of the parts to build a pretty decent 383, and I expect to have about $5K total in it.
That's with a Dart SHP block, Scat Competition Series 6" rods, Scat cast internal balance crank, ProMaxx Aluminum heads, etc. Every part is brand new.
I could have saved some money on the block, if I went with a new GM 350 block, so you could save several hundred bucks there.
You could even put a milder cam and still get that 380HP, running on low octane gas, and with great street manners. TechInspector1 has detailed this type of 383 build on multiple occasions.
Anyway, it's a free country, but I'm just sayin'...
