I just pulled the trigger and bought a set of Brodix race rite oval port heads with 270cc intake ports with 119cc chambers. Now I need to put an engine underneath them. I have picked out the rods, crank and pistons to make a 10.1 to1 compression 489. I have 2" super comp headers and will have 3" exhaust. This is going in an '84 olds cutlass, turbo 400 and 3.42 gears. The crank is a scat cast steel unit and the rods are scat 6.385" units. The pistons are forged Icon FHR pieces.
I know the heads seem small, but this is primarily a performance street engine. This thing will never see 6000 rpms. The only part I am not sure on is the cam. I know bigger engines can swallow a lot of duration and I admit I'm out of my element on this one. What I don't want is a cam that out paces the heads.
Doing my own research I came across a Howards hydraulic roller # CL-120325-08. 282/288 and 229/235 @ .050. Lift is .589/.601 all on a 108 LSA. Says an rpm range of 2000-5700.
After doing complicated math I came up with a dynamic comp of 8.0 to 1 and about 186 cranking compression. This seems like a very safe and streetable combination, but I am no expert. If anybody has any suggestions I would sure like them. As I said I'm out of my element on a motor of this size
