Building a SBC to rev to 8k, and have power
3 reading
108K views 52 replies 22 participants last post by  jhs914
Dont think you guys remember me... I have a 73 914 porsche with a 350 sbc.
Im doing some research and Im trying to figure out how to build an engine for it...
My purpose for the car will be a track and autox car (if you dont know what an autox is.. Heres a video of my last autox in the car
http://www.teamgracer.com/cars/videos/scca91605.wmv
For this purpose, autox especially, shifting gets in the way, and for track purpose, high rpm hp is king.
I would like to build my engine to rev up to 8k rpm's, be streetable, and probably make max power at 7.5k and cam profile starting it at 3500.
Under the cam I will still make a lot of tq for a 2200 lb car to move.. so im not worried.. Im concerned that a sbc engine will not like it up at that high an rpm.
My current engine is a 350, 4 bolt main, with smog heads (my limiting factor..) and a 3k-7k rpm cam, headers, FI, HEI, all that jaz.. It ran 240rwhp and 275 rwt. It makes max power around 5800. because of the valves, and valve float, and I havent seen it go over 6300 (except when reving it).
I was considering looking for a 302 crank, but those are extremely rare. Then I started thinking maybe a 327 crank, then IM now thinking of a 283 and boring it as much as possible. My uncle has about 2 dozzen cranks, and about 6 blocks and a "camaro" engine We can probably find a 283 in there, and probably a 327 large journal crank... usable is the question.
Rods and pistons dont matter, some H rods shot peened and cleaned I would assume would handle it. Compression under 11 would be good.
I love turbo's, and some day it will have a turbo... If this helps in giving it enough air to hold a rev that high while having a smaller cam lobe would be cool. Im a turbo guy.. but thats way down the road.
Camshaft is questionable. The transaxle choices make it interesting as far as were I will be cruizing at 75mph.. current transaxle (can only hold 300lbs tq) is around 3300rpms. but Im looking for advice on that.
Rocker arms Im considering full roller, and as light weight as I can get. maybe aluminum? Suggestions please.
Lifters Im also considering full rollers, but I dont know much about them..
Then there is the solid vs hydraulic.. Is it possible to go with a hydraulic at that rpm's? Good idea? Bad idea? I dont mind adjusting valves... previous engine in the car was a porsche 4.. and require valve adjusting, in a much more cramped position.
Intake manifold. I have a performer RPM currently, Will that be good enough for that high rpm's? I have very limited hood clearance, but can modify hood if I need another inch.. Tunnel ram is out of the question.
I also have Holley Pro Jection 4DI laptop programable fuel injection, and I can change anything on that, RPM's, Fuel curve (obviously) Fuel comp, idle, Electronic ignition curve, and some other good stuff. Impressed with it.
Distributor and electronics. Dont know. but would like to go electronic. HEI would be nice too...
Heads, I have double humper heads, would like to go aluminum.. but I am on a budjet.
I would like to keep this a low budget build, and will probably buy just about everything on ebay or summit on the cheep. Im thining about 3k would be a good budjet for the build. Considering that 600 would be needed in machineing for the engine rebuild and balancing, and the rest would be parts.
Thanks guys!
Andrew
#2 ·
a 302 crank is a 283 crank, not very rare at all. Chevy 302's are 283 cranks stuck into a small journal 327 block. SBC's generally don't like anything over 6,500 RPM max, normally 5,500-6k RPM b4 they give a fit and toss everything on the pavement. get a 4 bolt block, have it stiffened with the valley girdles ( I think that is what there called ), and hope that it holds togther, I don't think that any SBC will live to 8k RPM. :pain:
#3 ·
I disagree, a smallblock built right with good parts can be shifted at 9500 no problem, a guy here in town runs a 377 that twists to 9500shifts all summer long at the dragstrip.
Use a 400 block with main bearing spacers and a forged large journal 327 crank, the 3.25" stroke will help it live and it'll be 350ish cubic inches. I think JE makes a compatible piston. You'll want 11-1 compression or better and a long solid roller cam with good springs and rockers, good rods and 200cc heads, the airgap intake will fall off at 7K so a single plane intake would be the better choice. I have no idea if the fuel injection will work.
You are kind of pulling your motor in two different directions. You say that you want it to be streetable, and start making power at 3500 RPM so I assume that you are going to run pump gas. You also want it to make power to 7500-8000 RPM which will require a large set of heads and a big cam, and alot more compression than will be acceptable on pump gas. If you dont mind running 13:1 compression, you can do it, but it will not be making a lot power by 3500 RPM. I have a 358 (destroked 400) with 14.5:1 compression, 230cc runner brodix 11-x heads with porting and a cam with 274 @.050 ~.660 lift. That motor made 608 hp at 7800 RPM on an engine dyno. I had a 5000 stall in it and it was still not extreemly snappy off the line. The car previously had a 6000 stall and a turbo 400 with a transbrake. That was just about right on motor, but with nitrous, it was too much stall so we dropped it back to 5000 and a glide. I would focus on a ~6500-6800 max RPM if you are planning on running pump gas.
Adam
#8 ·
Ok, Lets assume I run it at 91 on the street (premium here), and at the track I run 100 octane, can I advance the timing a bit, and it will give me more top end?
I dont understand were the difference between 6800 streetable and 8000(or like posted 9200) race is...
There must be a way to compromise between the two...
Im not looking for a 600hp motor right now. If I did, it would be turbocharged.
Im looking at about 400hp, 350tq and alot of rpm's to work with.
I understand my goals are lofty, but I can always work down
Yes, the engine needs to be fully streetable.. but I dont see what is preventing this engine from reving as high as the other sbc's out there with bigger displacement..
I thought rod bearing spacers were bad? Anyone running them?
Would you trust them for 8k rpm's?
Andrew
#9 ·
Thanks guys!
Andrew
I see the problem right away. I don't see a reliable 8000 rpm SBC being built for 3K. $600 in machining costs seems way under priced for a quality build.
#11 · (Edited)
my $.02...
autocross is all about being instantly "quick"
autocross is 75% handling and the right tranny gears and the right rear gears
very probably the "other" sbc's are winding higher due to lower rear gears...not a 8000 rpm motor build....ask what gears they are using
if your post, 3300rpm=75mph is true, that's probably 3.25 or 3.55 rear gears, definitely not "quick" for how fast the motor CAN wind up under load...lower gears (4.56?) for much quicker will drive you nuts on the hwy
a 600lb 400hp 350 motor in a Porshe can be fast.....as in road racing....not easy to be quick in a slalom course with 3.55 gears
#13 ·
This car is a mid engine and uses a Porsche transaxle. Andyrew's was probably from a 4 cyl. 914 and was geared for a 4 cyl., meaning about 4.6 or so. You can't call Summit or JEGS and order a new gear for these cars. Remember, his car only weighs 2,200 lbs. with this gear. He doesn't need, and the transaxle can't take, much torque. I used to have a 914 with a Ford V6 (before it was flooded with salt water by Hurricane Ivan) and they are a blast to drive (pic below). A 2,000 lb. car with 200 h.p. and a 4.6 gear will scoot. I can't imagine the same car with 400 h.p.
I'm pushing 60 years old and can remember 283, 302, and 327 Chevy's consistently running to 8,000 rpm back in my youth. You older guys need to jump in here and help Andyrew out. I think he should build a 302 with a 283 crank and a small journal 327 block, or go with a 4 bolt 350 block using the 3" crank and 5.94" rods from the L99, 4.3 Liter V8, late model Caprice. Those were PM rods. He should be able to find a 4.3 Caprice in a salvage yard. I think there are threads on this board discussing the L99 to 302 build.
Andyrew’s biggest problem will be his budget. Building a high revving engine is not cheap. You will need some serious valve train parts and a well built bottom end Andyrew
#14 ·
red65mustang said:
my $.02...
Unfortunately, this is not your normal transmision.. this is a transaxle. I dont have much options on them.. Sure theres a couple gears I could swap out. but the " rear gears" are not avalible in different gearings without serious bucks, read fabbing up a new one...
In autox, generally you are in 2 gears, first and second, and on a fast course, 2nd and third.. In my transaxle I dont use first whatsoever due to the strength of 1st..
different transaxle options are out there, I wont discuss those because thats not the topic... lets just say there not cheep.
Haulin.. have you priced a rebuild on a 911 motor, let alone a turbo? 10-20k isnt out of the question for a simular motor as a sbc.
On machining. I just laid out a price.. I understand I need a lot of money in balancing and blueprinting everything... and thats were I'll pick up the top rpms and good reliablility..
jhs, The caprice engine is interesting, I think I might go with the 283 crank and 327 block though... hmm.
Heres a little about my car...
And I have somewhere near 10k into my car (including car), Coil overs on the rear, 275lb springs, koni yellows rear, reds front, 911 front struts, A calipers, Racing pads, vented rotors front and rear, 19mm m/c, Nascar front sway bar, v8 conversion (I wont even go into the engine... lol),flares front and rear, fiberglass front and rear bumpers, harness bar, 5 point harnesses, momo steering wheel, engman long kit, Rennshifter, seam welded rear suspension, couple of tubes for reinforcement, racing seats, and also, hoosier or kumho 710 tires. 255 40 17's front, and 285 35 18's for the rear street tires..
I understand most of that you wont understand... but I wrote that a while ago.. Car is in dissasembly, and the suspension is being seam welded and reinforced.
#15 ·
Andyrew,
I haven't been hanging out on the 914 Forum much since I got rid of my flooded 914, but I followed the construction of your car there when you were building it.
Just before the hurricane hit I was about to build a SBC to put in mine. I found a rebuilt 327 that I was going to use as a starting point. I couldn't find a L99 locally. You can get the rebuilt L99 cranks easily, but the rods are hard to find by themselves and are expensive new. GM still sells them, but not in sets. Out in Kali-Fornia finding a used L99 Caprice shouldn't be difficult. Think taxi cab.
If you use a small journal 327 and 283 crank you will have to use early 302 Z28 pistons and small journal 283 rods. With the L99 set up you can use standard 350 pistons, if I recall.
Race Engineering makes a 4340 steel, large journal, 3.00" crank that would drop in your 350 block. Last time I looked, it was about $900. Part #CO-LS30003A.
A 327 will be cheaper and easier to build than a 302. You could get a large journal 327 crank (used in the last 327's made in 1967 or 1968) and use your 350 block or find a 4 bolt 350 block.
A 302 uses a 3" stroke crank (283-small journal or L99/after market-large journal) and 4" bore (327 and 350 blocks are 4" bores. Early 327 blocks are are small journals, later 327 blocks & 350 blocks are large journal).
A 327 uses a 3.25" crank & 4" bore.
A 283 uses a 3" crank & 3.875" bore. Because of the small bore, large valve heads will have clearance problems with the block, according to what I have heard. A 283 will rev like a 302, but can't breath as well at high rpm's because of the smaller valves.
#16 ·
Back in the day,ive run both little high revvers and mid rpm longer stroke engines.IE: 277 cu in=11,000 rpms,331= 8500 rpms,the little engine didnt have any power till 8 to 9000 as it takes a huge head to get the power where you need it and needs all the tricks to stay together.*** valves,aluminum rods,light pistons,and it was always killing exh springs every pass. That destroked 283 was $7200 in 1981,so today would be crazy for a little engine. The 331 was in a 1950 lb anglia,and was very dependable at 8500 rpms and never hurt itself,but again it took light wt parts to make it live and rev dependably.
#17 ·
Would you be willing to tell me what was in the 331? What block, what crank, what size cam?
Thanks!
Andrew
#18 ·
Now this was in 1972 so I might not remember everything.
It was a .030 over 327 with a Hank the Crank crank,Howards rods and Venolia .043 ring with for at the time was high 13.2 c/r gas ported pistons.I had Either the 492 or the 292 head castings ported by Valley Head service with titanium valves and Smith Bros pushrods and Crane rockers with a Gk roller that was .654/.630 somewhere around 280@.050 i believe on a 109 seperation with a TR-1Y tunnel with 6224 carbs with 850 baseplates and a Mallory YC-465HP dist.This was current Pro-Stock tech then.
#21 · (Edited)
I will try to answer your question about a high RPM motor not being a good choice for a street car. First off, a high PRM motor by design will not have very good low end power. On the street, it is fun to have something that is snappy, and will break the tires loose at half throttle. If you have a high RPM motor, you have to wind it way up to get into the power to have any fun. Also, a motor with a large cam and a manual transmission can tend to "chug" at lower RPM's which is not very fun in stop and go traffic. My motor does not come togather and run smoothly until around 3000-3500 RPM. I dont think it would not be very fun to have to cruise up and down the street at 3500 RPM. The previous examples are matters of perference. If you dont mind those things, then it doesent matter. The following are more technical. First off, a high RPM motor means expensive parts. In my motor, I have a $2500 LAE billet steel crank, GRP aluminum rods and forged pistons along with a dart little M block. All this may not be necessery, but it is good insurance when you are spinning a motor to 8500 RPM. Also, a high PRM motor will probably not last as long. The faster stuff spins, the shorter the life will usually be. The last thing is compression. I dont understand this completely, but as cam size increases, more compression is needed to properly match the cam. If you run lower than recommended compression with a large cam, the motor will feel mushy. It will loose most of its pop. That on top of the fact that most of the bottom end has been taken out of the motor in the first place doenst make for a great performing motor especially on the street. As far as the reason for compression and cams, I would like some more info, so if anyone can give a physical reason for it I would be interested. According to the comp catalog, with 10.5:1 compression you are good to around ~250 @.050 duration. This will vary with the size of the motor, but it is a conservative place to start.
Adam
#22 ·
Adam
Guys,
Read his post, and watch his autocross video. HE DOESN'T NEED OR WANT BOTTOM END TORQUE! He is racing a 2,200 lb. Porsche with a 4.6 gear, using a transmission designed for 100 h.p. four cylinder. A high torque motor will rip the transmission and/or CV's out of this thing. You can't use 1st gear in these V8 914's because it will snap the output shaft in the tranny. If you watch his autocross video at the end he breaks a CV using his 350 smog motor.
If you are driving a 3,500 lb Chevy with an auto trans on the street, fine, run a 383. He is autocrossing this 2,200 lb. car and wants to wind the motor up so he doesn't loose time shifting (and this car demands careful shifts).
Now I will agree with your point (see my earlier post) that building a reliable 8,000 rpm motor will take big bucks. Andyrew is a young man who has built this car himself using mostly used parts and working around problems as he goes. What he is doing is an updated version of high school kids in the '40s and '50s dropping Olds and Caddy V8's in clapped out Model A's.
I've had the same car he has with a V6 and have done tons of research and talked to people who have built and driven these cars with V8's. Andyrew has the right idea for a motor for THIS CAR and THE WAY HE PLANS ON USING IT! Just because this motor is not right for you and your situation, don't throw cold water on his idea.
There, I feel much better now. :sweat:
#24 ·
jhs914 said:
Guys,
Torque is torque, no matter if it's at 3000 rpm or 6000 rpm. If you build a high rpm, high horsepower motor, it will make as much torque as any stump puller.
#25 · (Edited)
Not as far as the drivetrain is concerned, for two reasons.
A hypothetical example:
One motor makes 400 ft. lbs. of torque @ 3000 rpms and 290 ft. lbs. @ 6000 rpms.
A second motor makes 290 ft. lbs. @ 3000 rpms and 400 ft. lbs of torque @ 6000 rpms.
(Reason #1) Now, dump the clutch at the starting line at 3000 rpms (shock load the drive train). Motor one is transferring 400 ft. lbs. to the drivetrain to accelerate the car from a standing start. Motor two is transferring 290 ft. lbs. Which one do you think is more likely to break something in the drive train?
Now shift into second at 6000 rpms (another shock load to the drive train). Motor one's rpms drop back to 3000 rpm (hypothetically). Now you are shock loading 400 ft. lbs. again. Motor two is shock loading 290 lbs. Same question. Same answer.
(Reason #2) The transfer of 400 ft. lbs. of torque with the higher rpm motor takes more rpms from the motor but this also means the transmission/differential turns more rpms. This spreads the load. Think of the strain put on each tooth on the tranny gear. The same amount of torque applied at 6000 rpms vs. 3000 rpms is spread out over twice the number of gear meshings (if that is a word) at 6000 rpms. This means the loading on the gear teeth is half as much at 6000 rpms @ 400 ft. lbs. vs. 3000 rpms @ 400 fl. lbs.
Another way to think of it is striking a nail with a hammer. Swing a 10 lb. hammer at nail once every two seconds and you have applied 10 lbs of force to the nail every two seconds. Now swing a 5 lb. hammer at the same nail once a second and you have still applied 10 lbs. of force to the nail every two seconds. BUT, this time the nail never receives more than 5 lbs. of stress at a time. Which hammer is most likely to bend the nail? It's the same principle with the transmission/differential gears.
#26 · (Edited)
JH, if I'm reading what your saying correctly I think 99% of what you wrote is a bit off base. I'm trying to figure out where to start, as it made my head hurt.
Torque is torque. HP is torque over time. two taps of 5 ft/lbs of torque for 2 seconds is 5 ft/bs of torque. one tap of 10 ft/lbs of torque for 1 second is 10 ft/lbs of torque. Not that tapping has ANYTHING at ALL to do with what torque actually is. Just do a google on torque and you see the twist I"m geting at versus the hit deal.
Here is a head scratcher. When does a motor make the most torque? When it's stopped at locked rotor current. No time at all is being recorded as it's not rotating. No hitting, punching screaming just sitting there making torque.
If 400 ft/lbs of torque will break an axle at 3000 RPM 400 ft/lbs of torque will break the axle at 4000 RPM as well.
What is confusing you or you forgot is the torque multiplication in first gear versus a higher gear. That's the only variable in your reason two.
Reason one, I don't think anyone was arguing that issue at all. Of course on a low torque motor your going to rev it higher to take off so..............mute point in a competition application in most cases.
Torque is torque. Twist twist twist not hit hit hit.
