Trace the resistor wire, there may be one of two different configurations for your points which would be an external resistor mounted close by the coil or a resistive wire that runs from the "RUN" terminal of the ignition switch to the coil. There may be a second wire at the coil that comes from the "START" terminal of the ignition switch, this provides battery voltage during cranking only.
If you have an external resistor all you need to do is connect to the 12 volt side of the wire from the ignition switch to the resistor using a 12 gauge wire from there to the MSD. You just coil and wrap the old wire from the resistor to the coil in case you ever want to put the points distributor back in.
If you have the resistive wire, then you need to trace that circuit back to the ignition switch. That wire will connect to the "RUN" position of that switch. Add a number 12 gauge wire to that "RUN" terminal and run it to the MSD unit. Leave the resistive wire in place, coil and insulate cover it and securely stow it so its available if you ever reinstall the points distributor.
