Get a cam with about 70-75 deg's of overlap, That's a lot for a driver, but you can make it torqey. Get one on a 106-108 LSA,with as much lift as possible, then get heads from a 305 or fuelie heads with the small valves, and chambers, get bigger exh valves if possible. A little bowl blend and short side radius work for velocity. keep compression up around 10.5, get a dual plane intake, with either a q-jet or an anular holley, and a free flowing exhaust. Any catylitic's or exh. manifolds will kill you.
She won't be a monster up top, but she'll have a lopey idle, and pull from 15-1800
An overdrive and steeper gears would help. should be able to get a 850rpm idle.
Also, If you don't mind adjusting the valves twice a year, get a solid cam. Hydraulics tend to bleed down at idle reducing the actual duration, and taking away that nice brap-bu-bu-brap-bu-bu
Later
Steve
