carb base plate bolt pattern differences?
30K views 5 replies 4 participants last post by  eloc431962
Hi all. I bought a 1968 AMX with a 390 . It has an Edelbrock manifold that is stamped Edelbrock Torker AMC. I think the carb is a Carter spread bore. I want to replace with a Holley 4150 Ultra carb 650 CFM. Are there different base plate bolt patterns? Is the difference based on spread bore verses square bore? I think they make adapters but I really don't want to use one. Thanks for the help.
#2 ·
Yes they make adapters, But I don't think the torker amc will except a Carter spread bore carb without a adapter.JMO
I thought they were a square bore intake. So you shouldn't need a adapter to put the Holley carb on it .IMHO
Cole
