I finally got the 383 running with a Straub 288/300 cam. Fired right up and sounds great I set the timing at 14. I’ve only driven it a couple of vary short trips. Runs great until it’s fully warmed up.It will start to run crappy when the fan turns on it seemed. The fan auto temp switch won’t kick the fan on so I use the manual switch ( not sure what the problem is there) unplugged the fan didn’t help. Now I’m thinking it’s the rebuild Q Jet . When it gets up to Temp it starts missing lightly the idle will increase about 300 rpm then idle won’t stabilize and stumbles coming up the driveway.
The carb gaskets are soaked on the right rear.
Performer rpm not an airgap square bore manifold
1” adapter for the Q jet.
If anyone knows of a fix I may try it otherwise I’m looking for suggestions for a good non temperamental carburetor.
Thanks for any help.
