Carpet installation.. any tips, pointers, etc?
17K views 14 replies 7 participants last post by  slodat
I keep finding myself tending toward fitting carpet like I make a seat cover. Several pieces sewn together to fit the curves, transmission tunnel and such. I feel like I **must** be missing something obvious. This is one area I never got to learn from my dad before he passed.
Current project in the shop is really kicking my ***. An idea of how those more experienced approach this might really help.
Thank you in advance!
#4 ·
You don't need to sew the parts together at all. The way to approach it is to do the trans tunnel first with whatever padding you are going to use and a separate piece of carpet. (Make sure you run the carpet all one way, or it can look a completely different color) After the tunnel is done, put your padding on the floor on each side of the tunnel and fit the carpet around the tunnel in a "U" shape in the middle. You can either bind the edges of the carpet that butts up to the tunnel, or just glue it down next to the tunnel. Most automotive carpet is split in two under the middle of the front seats. Then the rest of the carpet is installed from the middle of the front seats to underneath the rear seat.
Look at how this carpet is installed. If you don't like the binding on the edges, just don't use it, just do something to the edges of the carpet to keep it from unraveling. CARPET INSTALL
Dan, thanks for the info, it is helping! Aside from binding, what other methods are there to prevent unraveling? Specifically when I have the tunnel carpet glued in place, I will need to "butt" the edge of the floor sections up to it. This is why I have sewn this in the past. It takes forever to sew it all up AND get good fitment. The backing of the carpet doesn't hold up well to that.
A little more info about the current project, it is a '78 Datsun truck. I know this should be really simple. I want this to turn out well, so I am asking for some assistance.
The floor was covered with sound deadening (eDead) and then I put down a layer of padding. This is where I am now. A few photos.
#6 ·
I would do this in three pieces. Cover the tunnel first, and then each side from front to back as a separate piece. If you don't want to bind the edges next to the tunnel, simply turn them under and sew them down, or if the carpet is nylon, you can heat the edges with a flame and melt the edges, assuming the carpet is black or at least dark.
Thank you for the advice and pointers! I ended up adding a dart to fit the tunnel. When I glued it down it laid completely flat against the tunnel. Not a single wrinkle or goofy spot, which is all I am willing to settle for. Still in progress. I know what I'm doing from here forward. Or at least that's what I'm telling myself.
I rolled the edges and glued them down. I like the way it looks so far. Feels good to see this coming together.
In progress...
#8 ·
I have been rolling the edges over and gluing them down. This works great when the line is straight and doesn't cross one of the rows of pile in the carpet. When it crosses rows, it looks like crap.
Exhibit A:
So, I bound that edge. I didn't want binding on all edges. Not the look I was going for. I think the one strip of binding on each side will look alright. I hope.
Exhibit B:
The rear section is almost completely "invisible" when the seats are in place. And the seat support (black painted part) breaks the line. So...
#15 ·
Dave, that dash pad came out of a parts truck that was purchased for the good dash pad. It needs to be removed and hit with some SEM dye to renew the color. They are exceptionally hard to find in good shape. When you find a good one it makes the whole interior look so much better. I have yet to see another option that looks as good as the stock dash pad in good shape. This is my shop truck.
