Hello guys I hope this is the right forum but I recently had some ignition issues and had issues of misfiring and had a older hei distributor and when it was running fine I was running a msd streetfire CDI box and my cd player played fine with no issues of electrical interference of any kind. I started to have issues in May and I changed out my spark plugs and cd player still did fine then I changed out my spark plug wires for a set of Jegs performance cut to length wires and cd player played fine and clean with no issues.
I changed out my toggle switch which I use as my 12 volt source for my distributor and thought my msd box was going bad and swapped out to a pertronix digital hp box and still was having issues of misfiring and of cranking and cranking and no spark a lot of times.
Long story short my pertronix box quit working and my old hei distributor the magnetic pickup coil was questionable and I had a spare hei distributor that is brand new and I am running straight from the distributor and no ignition box and with the new distributor installed my truck runs fine now and fires right up but for the first time ever I am getting some type of electrical interference when trying to play my cd player and it does not matter if its the radio or a cd playing or aux source but when the music is playing the peoples voices will start to break up and it has static like sound and never had this before from running a regular old hei distributor except really faintly before with certain performance wires but nothing so bad that it causes the music from my aftermarket cd player to start to garble up and static.
If my engine is not running its just fine. Cd player did fine before and no issues like this even with my problem with the pertronix box and previous distributor with curren jegs wires and ngk plugs. Since I unhooked the pertronix box and shipped it back to summit for replacement and swapped out my distributor for a brand new one and am just running the hei distributor with no external box it now has this problem and I don't know if the plug wires are just very low resistance wires or if the hei wire harness condenser is faulty or what. How can I tell what is at fault and is there anything I can do to fix this without having to buy different plug wires or a different wiring harness condenser?
Never had it like this bad before where it would make the music break up real bad.
