Chassis Problem
1.7K views 7 replies 6 participants last post by  327NUT
Hello Everyone,
I need help with material selection for my chassis. I am coilover mounting tabs and motor mounts from plate steel and I have a design but what thickness mild steel should I use.
I was thinking about 8-10mm thick but would this be overkill and should I go with 6mm, price is not an issue but it must be mild steel.
Thanks
A lot of things goes into play when building these things,, What type of tabs and motor mounts you will be building,,, There's ways to use 3/16 And different ways to use 1/4,,, So without knowing how you plan to do the mounts and tabs,, Hard to say,,, It has a lot to do with your welding skill's also..
Depending on how I make mine,, I usaully use 3/16...Or tubing,
There's all kind of ways to build Mounts and tabs..
Here's something that might give you some ideas on tabs and motor mounts..
http://www.hotrodders.com/forum/making-willys-frame-148235.html
http://www.hotrodders.com/forum/new-homemade-ratrod-making-138193.html
http://www.hotrodders.com/forum/building-homemade-c-cab-191990.html
#8 ·
Here's some pics of the 507" Cadillac installation after pulling the 327. I used some 1/8" plate and welded it to the boxing plates for a thickness of 1/4". The rest of the mount material is 1/4", could use 3/8 but that is probably overkill.
The tig welding was done outside during a breezy day so it's not perfect but it is very strong, drilled 4 holes in each plate to utilize some plug welding ....... I think most guys use 1/4" so don't get hung up on the thickness, just bevel the edges a bit and make everything is nice and clean for a good weld.
