what is the best thing to use for cleaning the carbon of of pistion befor i reinstall them?
thanks
thanks
piston tops only.Guy Hiltz said:A brass wire wheel on a drill is what I have used before,seemed to work OK.
x2.xntrik said:piston tops only.
Would probably work pretty good. Ever dropped a nail in a can of coke? Gone in less than a week!GMCTRUCKS said:What truth does soaking piston in Coca-Cola do for removing carbon off them I heard that once but never tried it.
its hard to snort coke pistons up the noseGMCTRUCKS said:What truth does soaking piston in Coca-Cola do for removing carbon off them I heard that once but never tried it.
I would not suggest applying oven cleaner {acid} to a set of pistons.joe_padavano said:Oven cleaner is the best, least expensive way to remove carbon deposits.
Be sure to hide it in a barrel so she thinks it's a shop-vac.techinspector1 said:If you are going to scrape or wire brush the pistons, run each one up to top dead center to do it, then use a shop vac with a snorkel attachment to vacuum the crud from around the ring lands. I've done it many times. No shop vac? Use mom's or girlfriend's or wife's vacuum cleaner.
Laughing out loud here.....jimfulco said:Be sure to hide it in a barrel so she thinks it's a shop-vac.![]()
