I was wondering I'm building a 400 small block.It has a 4.185 bore 6" rods,and a 11.1 standard flat top piston.The block has zero deck height,and the heads are made by Jegs Hi performance.there aluminum with 197 runners,and 64cc chambers,The cam I am running has a 600"lift Intake,and a 600" Exhaust.What I was wondering,is the valve going to hit the piston?Should I run a dish to keep this from happening?Is the only way this I can tell is to build the engine.The cam doesn't have a small base circle is it going to hit the rods?Will I have to grind the rods for clearance?How much power should a engine like this make?It has a open plenum with a 750 double pumper(victor junior intake) Holley carb.Here is the specs on the cam.Any info on what engine power should be,and recommendations on engine combo would be greatly appreciated
http://www.compcams.com/Technical/Search/CamDetails.asp?PaetNUMBER=12-470-8
For some reason the web site want pull up the specs,but you can click on it and put the 12-470-8,and then go to ick her,and it will pull up the specs.Once you click on the web site go to search,and then in the upper right hand of the page put in the part number.If you need them thanks for looking
