I've been using Energy Suspension front and rear mounts. The fronts use a clam shell on the block. The issue is that the passenger side mount deforms. When it deforms it settles and creates a minor clearance issue with the passenger side manifold. I've been changing the passenger side mount annually. I have no other issues other than that. The car is a G-body that is driven a fair amount, it makes about 450hp NA and 800 with boost.
Questions, what are the downsides of solid mounts? Will running a solid on the passenger side and poly on the driver side hurt anything?
Also, is there a replacement for a clam shell that still mounts to the same frame mount?
Thanks in advance - Jim.
