Hello Everyone!
I just purchase a GM 3970020 casting marine engine which I found out is a 307. It also had 010 and 020 markings behind the timing chain on the block which is supposed to mean that the Iron alloy used as 1% tin and 2% Nickle.
It has 2 bolt mains and uses no chain and has timing gear drives.
I was wondering if I can convert this engine to a 350 or not?
And is it after all a good block? I'm going to use Aluminum cylinder heads on the block + 3.48" strock crank.
The cranck which is already in the engine is a 307/327 crank with 3.25" strock. Is the crank itself any good to my engine?
Thanks very much for any comments/advises.
Houman SS '70
Houman SS '70
