coolant passages have bugs!?!
1 reading
3.5K views 14 replies 10 participants last post by  nmc77
I recently installed a 426 wedge that was rebuilt years ago. Before installing it I disassembled it to see what it looked like, and everything was new and clean. Bored out to fit std 440 pistons, heads done well, bigger exhaust valves. Installed it in a 65 satellite. New aluminum radiator new hoses. And Its overeating. After lots of reading and some disassembly, I've found two problems, one is easy, and one I need some help with. Problem one, big block mopar had two different water pumps, one for a/c cars that used a small pulley to turn it faster. This motor had the a/c water pump but the large non a/c pulley = turning pump too slow.. that's pretty easy, milodon high volume pump should work fine. Problem two is, when I drained the coolant it was dirty and brownish.So I back flushed the radiator into a paint stainer and got a larva worm and some bits of some bee's or wasps. I'm thinking mud dobbers in the coolant passages. I've flushed the engine with water till it's clean, but my concern is, those bug bits and worms clogging up passages. Any ideas to help get it cleaned out would be greatly appreciated.
#2 ·
Those F'n mud daubers get into EVERYTHING. I just pulled a set of 1/4 drive sockets out of my tool box. Every one of the deep sockets over 5/16" was completely plugged by those little bastids. The little worms were still alive when I poked them out of the sockets. I've had to use caps on every single air tool fitting because they plug those up. Open bolt holes in blocks and heads in the garage get plugged. It's a royal PITA. :evil:
#4 ·
A good flush is needed. I take out the thermostat and loop the heater hoses together to keep junk out of heater core. Pour in about a half cup of liquid laundry detergent. Top off with plain water and drive it about 5 -10 miles or even more if you want. Block off some of the front of the radiator with card board to get to normal temperature if needed. Remove both radiator hoses and remove block drain plugs and watch the junk come out. Allow engine to cool and flush block, radiator and heater core with garden hose to further flush junk and detergent out. Repeat if needed and then fill with 50/50 antifreeze and water.
I would just run the engine with the top rad hose disconnected and a hose in the rad to flush the engine, I think any sufactant may be overkill and be hard to flush out completely later.
The only additive I would use is a mild phosphoric acid like CLR which has sufactants mixed with it and add a teaspoon at a time as it ran with the top hose dumping to the ground. If you can, use hot water to keep the thermostat open or remove temporarily to allow unrestricted flow while you flush.
Once you get large bits out I would think of taking it in for a professional flush, cheap insurance if you ask me. Reverse flowing the rad and heater core is done on a flushing machine which will save you the aggravation of trying to do a good job with limited options in your driveway.
You may even decide to just let the garage do the entire flush, tell them the issue and let them handle it...they do it for a living and have equipmemt designed to do the job.
#10 ·
Thanks for all your input. Sorry I'm being so wordy.
I need to mention, this over heating started after first longer drive. Ran quite a bit before over heating started. Even sat idling while charging the vintage air, without getting hot.
Here's where I'm at. After removing radiator, water pump and t-stat flushing everything with water hose, decided that while I'm waiting on parts, I'd put everything(except t-stat) back together and run some laundry detergent/water in it. Left the rad cap off ran it mostly idling, fans kicked on at about 175, temp just kept climbing. Had a huge squirrel cage fan in front. Shut it off at about 210. Let it cool down, removed rad and back flushed, this time I got what looks like an odd cricket. So I figured I'd better remove some freeze plugs. Took out the rear one on each side. Both had a considerable amount of rust chips and crud at the bottom. Not a lot, but thought I'd mention it. Flushed out again, rust stuff cleaned up nice, didn't see any bug bits come out. New pump should be here tomorrow. I'll put it together again and pull the top hose and try the CLR idea.
My concern is that I didn't see nearly enough stuff come out to stop the overheating.
Any thoughts on anything else I should do before I put it together?
#11 ·
What kind of fans are you running? The age of the car would dictate mechanical but I had to ask to be sure. If mechanical are you sure you put the blade on the correct way? I've seen it many times on older cars where a non-thermostatically controlled mechanical blade was put on backwards and it was pushing air towards the radiator, instead of pulling air through the radiator.
#12 ·
I would not run the engine with the radiator hooked up! Whatever breaks loose in the form of bugs, or nests will plug the radiator! Put a hose directly into The radiator hose at the bottom. Since coolant flows out of the top of the engine, you'll want to wrap a rag around the hose, to keep the water flowing into the lower hose. Direct the upper hose to a point it wont be a problem. Also remove the thermostat, to allow free flow. You can do this without the engine running, but a little warmth may help break the junk loose, so you could fire it up and idle it also.
Once there's clear water flowing, and no sig of the bugs, you should be good to put it all back together again.
#15 ·
So here's an update. After flushing everything forward, backward, inside out, upside down, about 6 times, including removal of two rear freeze plugs. Installed milodon high flow pump. Changed to zerex coolant with water wetter. Still over heating. Removed the two 10 inch electric fans and the shroud that came with rad/fan kit. Installed the biggest mechanical fan I could fit. Over heating problem got better. So then I made a custom fibreglass fan shroud and now it stays around 180 when driving, still climes up over 210 at a stop. I'm hoping that after the engine gets broke in and it loosens up that the temps will continue to calm down.
