Status
Not open for further replies.
Correct Fluid for a Powerflite transmission?
9.4K views 8 replies 4 participants last post by  stuarta
What is the correct transmission fluid for a 1954 DeSoto Powerflite automatic transmission.
The pan leaks and I have a new seal. What should I be using for fluid?
Any "gotchas" I should be aware of with this old transmission?
#3 ·
Those old blisters were not that fussy on fluid types.
It is a straight forward process to replace the pan gasket.
Unscrew the filler tube. Remove the pan bolts.
Make sure the bolt holes aren't pushed out of shape.
Clean the pan and sit it on a bench with the bolt holes down.
Look for any light visible. Keep flattening the pan until is is straight.
No need for any sealant on the gasket.
Tighten the bolts evenly to about 10ft pounds.
#4 · (Edited)
Thanks, guys. I have a new gasket on hand.
This looks to be straightforward.
The service manual says I'll need 5 quarts and instructs me to drain the converter as well. There are two drain plugs and an access panel.
I'll be changing the oil as well; might as well grease the suspension fittings while I'm at it.
The service intervals on these older cars don't seem to be very long.
#9 ·
That works provided you don't drill into the lockup clutch.
You would be looking for the a s s kicking tree. :D
You are much better off disconnecting a return cooler line fitting, adding fluid and pumping it through until it runs clean.
Status
You have insufficient privileges to reply here.
