well here we go again - more problems..............
I was disassembling and cleaning my hydraulic lifters on my 454. It was going well until I got to the rear cylinders and found I could not remove the lifters from their bores on cylinders 7 & 8. Upon further examination I discovered there was slight damage to the cam lobes (on the edges) and the edges of the lifter bases. The lifters would not come out of their bores as a result - clearance was too tight. It appears the cam lobes are not aligned well with the lifters (is that normal on a BBC?) and eventually the lobe edges starting eating away at the lifter bases.
I'm running a comp cams 11-250-3 hydraulic extreme energy FT cam.
What do I do now? I need to get those lifters out and they won't clear the bores.
1) do I have to pull and replace the cam?
2) do I have to replace the lifters?
3) what caused this? Are the cam lobes and lifters supposed to be perfectly aligned - mine are not. I don't want this to happen again.
Lee
Lee
