Yes the Dart SHP uses the '87-95 factory roller lifters, or if you want link-bar type then they are +300" taller than old Gen 1 retro-fit type.
Right from Dart web page for the SHP block...
"• Uses + .300” tall stock 87-95 roller lifters."
You don't have to use link-bar lifters...but the SHP block is set up for the factory style rollers if you want to take advantage of that., if you want to use the factory spider and guides.
I would be using a better lifter than the Howards you've picked, that is their base level lifter.
