TechInspector: was reading your post in another thread about compression ratios..
his particular 406 was set for zero deck height... I didn't measure the deck height when I assembled my 350 (one of the many lessons I learned after my first build)
do you have a general figure for deck height/volume I can use for calculating my SCR?
I suspect my SCR is higher then I expected to be because my engine has turned out to want premium only if I want to run enough timing to make power..
it's a stock 350 block, bored .030. I don't believe it had ever been apart before I disassembled it. (got rainwater in a cylinder, thats why I had to go .030) i'm running a basic felpro composition head gasket.
with SpeedPro PowerForged flat-top pistons with 4-valve reliefs.
L2256F appears to be their part #.
