Ok, I hope I can be understood on this. First, this is what I have, a chevy ' 78 350 4 bolt main recently completely rebuilt by yours truly; with the exception of the machine work. I have ported and polished the cylinder heads which are a 882 castings, 1.94 intake valves, and 1.5 exhuast valves. I have Harland Sharp 1.5:1 roller rockers with screw in studs and quide plates.
Everything is new. I have already run the motor for 20 minutes or so.
I then partially took it back apart just to check things out. This was the first time on a complete rebuild, so I wanted to be safe.
This is my question;
On the valve stem where the roller rocker tip makes contact, there is a very fine horizontal line wear the roller bearing from the rocker arm has been riding that is located about half way between the outer edge of the valve stem and the center of the valve stem. In other words it is not riding in the center of the valve stem where I would feel more comfortable. Should I be worried about this being a condition that may get worse over time or what? Also, I set the clearance between the roller tip and the valve stem at .020, and 022 for the intake and exhaust valves. I assume this was ok for initial start up.
One more thing, the cam I am running is from Crower p/n 00321. Its a solid with intake lift .482 and exhaust lift .504
Should I think about getting different length pushrods to get the roller tip from the rocker riding in the center of the valve stem?
