drilled through water jacket 350 engine
8.1K views 11 replies 7 participants last post by  Richard A
#1 · (Edited by Moderator)
Hey guy's need alittle advise, I have a 350 motor putting together. I was putting on the brackets on the side of block "Driver side" for the motor mounts. There's three bolt holes the bottom one I broke the bolt. First step drill pilot hole, well you could say I went through the broken stud in block. Remeber it's the bottom stud. My plan of action tried easy out no luck the bolt had loc-***. Long story shot re-threaded the hole cleaned out area, filled the new bolt hole with Ultra Grey high torque RTV silicone and then put loc-*** on bolt. I'm suppost to torque the bolt down to 75 ftp, I didn't want to push it so i put 50 ftp, the top two are at 75ftp as my book require's. Will I be safe with this repair? Learned valuble lesson "NOT TO USE OLD BOLTS". Also the reson I only went 50ftp was cause I broke one in the same area but was able to remove. What the ******* lol!
Discussion starter · #11 ·
I have a Haynes book for a 73 impala, the actual motor mounts on frame are at 50 ftp and the mounts to block are at 75ftp. was justb tringto follow the book torque spec as i put on new parts. Who knows?
