Edelbrock 1406 Flooding, etc.
1 reading
8.7K views 8 replies 6 participants last post by  AutoGear
I have an Edelbrock 1406. First question is what causes the bowls to be empty after engine sitting off over night ? This seems to be intermittent. Sometimes it starts right away after 2 days of sitting off, and sometimes it's dry the next morning & I have to crank for several seconds to get fuel in the carb.
Also there is a flooding problem. If the engine idles like at a stop light too long, when I try to accelerate the engine runs very rough like it's flooded or not getting enough fuel, then clears up in several seconds.
I have a fuel pressure regulator set for 5 psi. I rebuilt it yesterday with all new gaskets. Set the floats @ 7/16 in & 1 inch as per the book, but didn't check the floats in water for leaking but they seem OK ??? Also I didn't change the float seat-valves but they look OK ??? I let the engine idle for a long while & it flooded out like it was severely flooded & wouldn't re-start. This morning I had to crank the engine for a long while to get fuel to the carb.
I had a supposed "carb pro" work on it 6 mos. ago & they had not done it right. I'd bought a rebuild kit for it that I think had float seats in it, but don't know if they installed them ??? I had to rework it myself (wrong screws in the primary venturi booster & 1 missing seal-plug causing flooding.) After that it was running OK but started to get idle-flooding again.
Thanks, Paul Hillman
#2 ·
LOwer your pressure. Your gauge might be wacky.
The empty bowl is from the fuel percolating out when you shut it down. Depends how hot it gets determines how much is left.
What's the elevation where you live?
You might need to lower your floats a bit.
#3 · (Edited)
Check to make sure your needle/seat are sealing. On one of my carbs the seat was milled a little deep not allowing the needle to seat and seal, required two seat gaskets to raise it slightly and allow the needle to seal correctly.
Also check to make sure your transition slot is not uncovered to much (throttle stop adjustment).
Have met a lot of carb pro's that talk a good story but actually know less about carbs than I do, and that ain't saying much...
Just re-read your post where you said "you didn't change float needle and seats". Always change the needle and seat!
#4 ·
I lowered the pressure to 4 psi. Will see how that works. Elevation here is 360 ft ASL, (north of Houston, Tx)
The carb to intake manifold gasket is thin 3/32 in. Is there a thicker gasket ? Some guy told me the other day about him having to get a thicker spacer for lowering carb-heat. My previous carb was a Rochester Quadra-jet & I had no problem with losing bowl-fuel-level. (As I remember)
Paul Hillman
Got the truck running this AM, at 4 PSI & the first road test was OK, but it screws up with longer running time & heat build-up. If problem persists will change float needle & seats.
This 1406 is on a '79 chevy C-10 pickup with a 350 small block.
If it is like my '75 350, from the factory your Quadrajet probably came with a spacer that is about 3/8" thick. You should try using at least a 1/2" spacer with the Edelbrock to give you some heat insulation, and you might even use a thicker spacer. Use one made of phenolic or wood, not metal.
Bruce
#8 ·
X3 on the spacer. This is getting too much heat from the intake into the carb body. Houston is one place where an air gap makes sense. Check the exhaust system some of these trucks have a heat controlled valve at the exhaust manifold to head pipe joint that is intended to speed warm up by forcing exhaust through the intake's crosser over . If this gets stuck closed the intake gets really hot.
#9 ·
not to pile on; but I like the CoolCarb spacer for the Edelbrocks. But as the website (now) states "not for intakes with EGR or heat crossovers" That localized hotspot will deform the poly inner core.
Order Products
Hot start issues? GONE. And they only take up less than a quarter inch.
The marina I worked at installed a lot of these on ski boats, a lot with Edelbrock or Carter carbs. Towing a skier generates a lot of heat. Skier falls down, boat stops, putters back to skier and turns off...has trouble restarting. Class racers love the ones marked "same size as gasket". LOL
