The Edelbrock does not have the option to idle in closed loop.
67chevy said:
I'm useing a edelbrock air/fuel meter and idle is still running at 13.0/1
I had an Edelbrock A/F ratio meter with the pretty lights, but verified with a wide-band that it is not very accurate. You really need a wide band to see your actual air-fuel ratio.
If you are leaning it out and still reading 13-1, either the system is not responding to the changes, or you're simply not getting an accurate measurement from the narrow band meter.
Rick WI said:
No matter what the A/F ratio tells you it is the motor wants what the motor wants. Some may not to like to run as lean as others.
Amen to that!
Getting the idle right was very frustrating for me with the Pro-Flo. According to Edelbrock tech, this was (is) a common problem, especially with a bigger cam (over 230* @ 0.050). They later revised the chips to give a false temp reading with TPS at idle. I think it was like 50*F, but I cannot remember exactly. But once you moved the throttle it read the real temperature. This was supposed to help with the heat problem as it related to idle. As the temps rose, sometimes to over 135*F, it was leaning out bigtime. And it was even worse after a hot restart. I was told by Edelbrock that changing the air temp (artificially) was designed to help combat this problem.
My engine with the Performer RPM cam likes about 13.0-1 at idle. I verified using a wideband that it could set perfectly using the Pro-Flo system and it would later lean out to over 16-1 when temps rose above 135*F. Needless to say, it ran horrible like that.
Ed
