The C3-Bx came with a notch cut in the plenum divider positioned specifically to clear the wide, solid, single rear throttle blade on the Holley Model 3160 List #3916-1s 950 cfm 3 barrel carb or the List #4604 1050 cfm 3 barrel, which debuted in either late 1967 or early 1968,.... so that would place the intake at that same time frame and continuing to around 1973 or so when the 3 barrel was officially dropped from
production.
That's where the "3" in "C3-BX" came from, as Edelbrock also made a identical manifold without the notch, called the "C4B" and "C4BX"("Chevrolet Four Barrel" and "Chevrolet Four Barrel Extra"). The X denotes slightly larger internal dimensions compared to the non-X models.
I've got a couple of those 950 3 barrels, they were a "HP" carb 40 years before Holley officially used the HP moniker to describe choke tower -less carb main bodies.
The 3 Barrel became overshadowed in late 1969 or 1970 by the introduction of the larger base "Dominator" Model 4500 series carbs.
Still a great carb if you know how to tune Holleys well, and I've found it a nice gearhead conversation piece as many have never heard of them.
