Same as factory 25-30 ft pounds. Use a hardened washer between underside of bolt and aluminum intake. Neither washer or bolt should be plated either plain or stainless steel. Zinc and galvanize are reactive with aluminum when wetted.
Some intake fastener holes of the head are closed while some are open to either places with coolant or oil. Fasteners going into blind holes only need thread lube which is engine oil in slipperiness, this has an effect on torque readings so super lubes are not recommended. All threads should be chased to insure they are clean snd straight. Threads open to coolant or oil must be sealed, in this case a thin coating of Permatex Aviation Gasket Maker #3 is my recommendation as it firstly offers thread lubrication similar to 30wt oil which is what the OEM’s base their torque numbers on and secondly it is a pliable non hardening sealer that well insures that coolant nor oil will pass up the threads.
Unless your using an air-gap intake you will find that unless your living in a very cold climate that aluminum intakes do not need exhaust heat, so choose an intake gasket that seals off the exhaust crossover passages if that suits your operating climate.
You will also find that carburetors on aluminum intakes acquire enough heat transfer from the manifold that modern fuels formulated now for nearly 50 years to support the needs of high pressure fuel injection tend to boil off in carb float bowls so I recommend at least a 1/2 inch thick insulating spacer between the carb and the intake. The Edelbrock carb is particularly sensitive to this but not necessarily alone though the Rochester and the Holley are usually less troubled.
